Inverting a signal without amplification
Discussion in 'The Projects Forum' started by Flamin_D, Nov 15, 2010.
  1. Flamin_D
    May 3, 2010
    18
    I hope someone can help me invert an analoge varying sine wave signal without amplifying it. I have looked into OP amps but they all seem to give an amplification. I have seen basic diagrams that look like what im looking for though:
    Would this work for me? what value resistors / transistor would you suggest? Im working with milivolts, the values given out by an audio pre-amp.
    Thanks in advance
  2. mik3
    Feb 4, 2008
    4,846
    63
    Use two 100K resistors for R1 and R2.
    Have u considered using a low noise op amp since you are working with low voltages?
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
  4. Flamin_D
    May 3, 2010
    18
    Ok great thanks - fairly new to opamps, what differences are there? What model would i go in search for?
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    I ofthen use the TL071 (single), TL072 (dual) or TL074 (quad) opamps.
    I have attached the datasheet for you.
    I also attached a kind of opamp handbook.
    Bertus
  6. Flamin_D
    May 3, 2010
    18
    Great, thank you! I will use pins 2, 3, and 6 with the stated resistor vaules.
    Cheers this forum is brilliant!
  7. mik3
    Feb 4, 2008
    4,846
    63
    We give some quick solutions but it doesn't mean they are the best solutions. They will work but there might be better solutions. Keep this in mind as to seek for improvements if required.
  8. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    Also keep in mind that the shown circuits will work for dual powersupply.
    If you are using a single powersupply, take a look at the attached PDF.
    Bertus
  9. Flamin_D
    May 3, 2010
    18
    ahh ok... i am after an amplification of -1, Just inverting the wave really, would this work or would i need a power supply as you say?
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
  11. Flamin_D
    May 3, 2010
    18
    the signal is going to range from 15hz to 200hz most likely, its from a subwoofer preout
  12. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Your circuit in post#9 has the inverting (pin 2) and non-inverting (pin 3) inputs reversed.
  13. thatoneguy
    Feb 19, 2009
    6,357
    718
    What is the application for? I'm assuming a subwoofer, do you already have the sub?
    The sub for my computer speakers (Sunfire Subwoofer) has a phase adjustment on it from 0-180 degrees. Others I've seen have a switch for 0 or 180 phase shift. Is this similar to what you are trying to achieve?
  14. Flamin_D
    May 3, 2010
    18
    thatoneguy,
    I have a subwoofer pre-amp which only gives frequencies below 200hz in the music. This is then connected to the subwoofer amplifier, which is a stereo amp (therefore i have split the single signal from the preamp into two, so they can be plugged into both left and right inputs on the amp). What i am trying to do is invert the signal of ONE of the signals, for example on the left hand side, so that the phase from the positive speaker terminal is reversed. This would mean i could bridge the amplifiers inside by connecting a subwoofer to the two positive terminals of the amp.
    I hope this makes sense without a diagram!
    PS. i did wonder why pin 2 and 3 were backwards, i got the main image of the opamp from google images like that.
  15. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    I suggest using 10k resistors, as that matches the impedance of line-level audio.
  16. Flamin_D
    May 3, 2010
    18
