inverter
Discussion in 'General Electronics Chat' started by cliffton86, Apr 8, 2011.
  1. cliffton86
    Apr 8, 2011
    want to know that do i have to isolate the neutral of inverter with the mains neutral for new connection.
    Please do the needfull,
    thanking you,
  2. R!f@@
    Apr 2, 2009
    8,792
    771
    Welcome
    What the heck are u talking abt?
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
  4. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    It depend on your inverter as if it is Online then you have isolate it from neutral as the output of it remain on, for offline you may connect both neutral outputs together!!
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    I would connect ground together, but not neutral.
  6. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Why......??
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    Because Neutral is part of the current path. Ground is meant to be the common wire, but Neutral is not.
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    "Ground" in this case refers to a protective "earth ground". It is for the protection of humans.
    Normally, the earth ground carries no current at all, nor should it be used for that purpose; it is simply there in case there is a short from the mains power to the case of the equipment. A short from mains power to ground will result in the circuit breaker or fuse opening up, instead of having mains power connected to the equipment case - which would be a dangerous situation.
