Hi guys,
I live in India. Ac voltage here is 230V 50Hz
this wiring is for a office building which has two 3-phases, 1-single phase
and i will run the inverter on generator power as well (>10KV generator)
I want to power 540W of cfl's(30 18W cfl's)
my inverter is 800VA, with 150Ah battery
Now what happens is inverter runs for 30 minutes, "battery low" lights up, output stops. but after 5minutes, again it outputs power, but all lights(cfl lamps) start blinking, until the load is reduced
and one more doubt, when will inverter fan run?
