inverter using ir2101
Discussion in 'The Projects Forum' started by lovelyhakeem, Sep 22, 2013.
  1. lovelyhakeem
    Dec 15, 2010
    23
    Dear members,
    I have designed full bridge pure sine wave inverter using IR2101 with specs
    Mosfets : irf740
    mosfet driver : 2101
    boostrap capacitor : 67 Uf
    Gate to source res : 1 Kohm
    main issue when i give about 125 DC to mosfet drain , pure sine wave produced
    but when i give 300 V DC dirctly to make 220 V AC , sparking produced in MOSFETs ??? any idea how to overcome this issue ?? plz help
    Thanks alot
  2. t06afre
    May 11, 2009
    5,939
    1,222
    I think you have to show us your layout and schematics (full not just some part if it)
  3. lovelyhakeem
    Dec 15, 2010
    23
    it z simple diagram , just connect pin 1 to Vcc , 2 and 3 to high and low signalfrom microcontroller , 4 to ground and a capacitor between 1 and 4 pin of it2101 , pin 5 and 7 to gate of irf740 with low value resistor and a capacitpr between 6 and 8 pin of ir2101 of 68 uf . gate to source res of mosfet is about 1 k . plz help
  4. #12
    Nov 30, 2010
    16,690
    7,330
    That is not a drawing. It is also not a photo of how you connected the parts. We can not work with words because they do not show the mistake, only the intent.
  5. killivolt
    Jan 10, 2010
    432
    351
    Put 2 Zener's back to back between G and D.
  6. t06afre
    May 11, 2009
    5,939
    1,222
    It is also very important that you point out where the sparking occurred
  7. killivolt
    Jan 10, 2010
    432
    351
    I don't know why you have created another "Thread" on this?
    However, this is taken from another forum, I don't know what your doing and why, that would be helpful for the Senior Members to help you.
    I'm trying to learn these things myself, in my own project, different problems, and of course a different circuit not related to yours.
  8. shortbus
    Sep 30, 2009
    4,095
    1,684
    Since your mosfet is only rated at 400V, that may be the problem. Mosfets should, as a rule of thumb, be rated at twice the input voltage and input amperage.
    killivolt likes this.
