Inverter using 16F84
Discussion in 'Embedded Systems and Microcontrollers' started by dreal007, Apr 9, 2011.
  1. dreal007
    Apr 7, 2011
    hello guys pls i need your help to generate a 50hz sinewave signal for an AC inverter using pic 16f84
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Is this a school assignment? It's so much easier to make an op amp oscillator than with an obsolete microprocessor.
  3. THE_RB
    Feb 11, 2008
    5,435
    1,305
    True, but the microcontroller will provide xtal locked frequency accuracy and also allow push-pull sine output if needed;
    Here's one I made earlier; ;)
    http://www.romanblack.com/one_sec.htm
    (see about half way down the page there are a few examples with schematics and source code)
