INVERTER that can on a lamp and a 21 inch tv...help please
Discussion in 'The Projects Forum' started by eyestorm, Jul 16, 2011.
  1. eyestorm
    Jul 16, 2011
    anyone could give me a circuit of a simple inverter....thanks....email me...<SNIP>
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    We don't help via E-mail.
    You should remove your E-mail address so that it does not get picked up by the spam-bots.
    You really should state the total wattage requirement of your lamp and TV, and how long you want it to operate without mains power; and also what the output voltage and frequency needs to be.
  3. lokeycmos
    Apr 3, 2009
    432
    7
  4. iONic
    Nov 16, 2007
    1,422
    68
    Unless you have most or all of the parts, your best bet is to buy one.
    Here is but one source where you can purchase them according to your power needs.
    Harbor Freight Tools
  5. Adjuster
    Dec 26, 2010
    2,147
    300
    Note that if you are expecting 100W or more to run a CRT-type TV and a light for some hours, you will need a BIG deep-cycle battery. A car battery just won't cut it.
  6. raffter
    Feb 28, 2008
    113
    eyestorm
    by -simple- means a really simple one in design, right? I think square wave output inverters could do a nice job powering up lamps and TVs
