Inverter question
Discussion in 'General Electronics Chat' started by Antish, Jun 23, 2009.
  1. Antish
    Jun 13, 2009
    5
    hi
    can it possible to produce 220/230vac from 12/24/48vdc car battery continuously(with out interrupt) at least 24/48 hours?if yes,how?does it work for all kind of power conveter? if no,why?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Last time I tried this on my car my alternator blew several hundred miles later. Approach with caution.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    First, please post questions in an appropriate section.
    Yes, an inverter can produce an AC voltage for that period of time, provided that the battery/ies have the capacity to supply the current. In other words, it depends. With no parameters, that is about as good as it gets.
    How? - by being able to supply the necessary current.
    Not sure about -
    - that is too broad to answer.
  4. dontium
    Feb 12, 2008
    6
    Can be achieved!
    可以实现方波(Square wave), 正弦波(sine wave),频率可以由50Hz--100kHz,Decision in accordance with output power of generator capacity
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    When the battery is discharged too much (from the current that you did not talk about) then the inverter stops. When the current is high then the battery charge will not last long. When the current is low then the battery charge will last a long time.
