Inverter output is reading zero
bertus
Joined Apr 5, 2008
22,277
It looks like the fets are a to heavy load for the circuit.
Do you have an oscilloscope or frequency counter available?
If so you could check the frequency of the outputs 10 and 11.
(the fets should still be disconnected).
Bertus
bertus
Joined Apr 5, 2008
22,277
It could be possible that the fet connections are wrong.
Here is a picture from the datasheet:
I hate also attached the full datasheet.
Bertus
nobleman
Joined Apr 17, 2015
20
sir bertus, Thanks for ur time u have really being helpful, I will reconstruct the circuit with this new finding and pray it work out fine
wayneh
Joined Sep 9, 2010
17,498
For what it's worth, the IRF540N that I have on hand matches the pinout in the diagram provided by bertus. The tab (pin 4) is drain, same as pin 2.
