Inverter not working
Discussion in 'General Electronics Chat' started by hnajee, Aug 25, 2014.
  1. hnajee
    Aug 25, 2014
    The 25 amp fuse blew and replaced it with a 20 amp fuse (couldn't find a 25 amp fuse). The inverter would not charge and the red light that shows inverter is charging is not showing either.
    Will appreciate assistance.
  2. wayneh
    Sep 9, 2010
    12,405
    3,255
    Inverters don't "charge". Are you talking about a battery charger? Maybe a UPS? Naming the make and model might help experts here understand what you are dealing with.
    Whatever blew the fuse may still be a problem, or may have caused other damage.
    Is the 20A still good?
    If there is indeed a battery in the system, I'd start by removing or replacing it. Or at least checking it.
