Inverter ( NOT Gate ) not working
Discussion in 'General Electronics Chat' started by venkee, Dec 26, 2011.
  1. venkee
    Nov 12, 2010
    Newbie question.....
    I am testing a simple inverter I made as per
    http://www.kpsec.freeuk.com/trancirc.htm
    At the output I have connected a LED via a resistor.
    Problem: The output ( LED ) is always ON whether the base current is switched on or switched off.
    I attached a LED after the emitter. And this is OK , ie it comes on only when the base current is on.
    Could somebody kindly clarify ?
    Thanks in advance.
    Venkee
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The circuit you're trying to use:
    The circuit you should be using instead:
    See how similar they are?
    Basically the same thing. Just put your LED in series with Rc.
  3. venkee
    Nov 12, 2010
    Thank you SgtWookie.
    As I had mentioned, I am testing this circuit and had put the LED only for testing. Actually I need the inverted signal to control another part of the circuit.
    How do I do it then ? ie get the inverted waveform....
    Searching the net for such NOT-gate-type inverter turns up so many circuits but they are so similar to this....
    I dont know what is it that I am doing wrong.
    I have been testing the circuit with 4.5 volts.
  4. praondevou
    Jul 9, 2011
    2,936
    489
    In this case your first circuit should actually work.
    - what transistor are you using?
    - how does the circuit you want to control look like?
  5. crutschow
    Mar 14, 2008
    13,511
    3,385
    What is the control signal?
    Double check your wiring.
  6. sheldons
    Oct 26, 2011
    616
    101
    your circuit may be picking up noise if the base is floating and the transistor is sensitve enough.....both these circuits work(with an additional pull down/pull up resistor)
