inverter implied with nmos driver and pmos diode load.
Discussion in 'Homework Help' started by vustudent, Oct 16, 2010.
  1. vustudent
    Thread Starter Active Member
    Mar 11, 2009
    38
    Here is a inverter design of a nmos driver with a pmos diode connected load.
    Vdd is 1.2V, input is DC biased at 500mV with 50m AC small signal.
    the pmos attributes are set as the follow:
    vto=-0.42
    uo=90
    tox=3.2n
    gamma=0.24
    kp=0.933m
    I would want to fix kp to this value, since i would then have an output resistance of 1/gm , which would gives me ~25M Hz bandwidth with a 1pf load.
    The gain equation for this inverter is -gm(nmos) * Req(pmos)
    = -gm(nmos)/gm(pmos)
    which boils down to [​IMG]
    To get a gain of -2
    I set Kn = 4Kp
    nmos attributes:
    vto=0.39
    uo=518
    tox=3.2n
    gamma=0.28
    kp= 0.933m
    The output is biased at 560mV and i got a gain ~-2.
    Then I tried a gain of -1
    set kp=kn
    and got I below:
    The output in green is now biased at 670mV with a gain of -1
    My question is how is the biased output voltage determined, and how do I control it?
