You have 2N7002 in your sim, passing ~ 500mA peak current. A CD4007 can only source/sink a few mA.I designed my circuit alike though using an CD4007 to generate an inverted signal.
To clarify, I think he's trying to say that the low current is not enough to quickly switch your mosfet. The 2N7002 draws essentially zero static current on the gate.You have 2N7002 in your sim, passing ~ 500mA peak current. A CD4007 can only source/sink a few mA.
I already said that you need a p type mosfet, the CD4007 can't driving the Vgs of N ch mosfet to make Vds get into the saturated situation.I had so much issues with the full bridge inverter so decided to use the half bridge inverter. Please see schematic in attachment. I designed my circuit alike though using an CD4007 to generate an inverted signal. My Voltage output was 0.8V compared to ~6V on the simulation. I'd appreciate some clarification here per what i'm missing or doing wrong. I do have present an update on the progress of this project.
by Duane Benson
by Jake Hertz
by Duane Benson
by Jake Hertz
