Inverter connection
Discussion in 'The Projects Forum' started by vaibhav1515, Jun 15, 2013.
  1. vaibhav1515
    Jun 15, 2013
    I am from India and I want to know that can an Inverter be connected to neutral wire of household appliances (fan, bulb etc). When the supply is off then the phase wire will work as neutral. But when supply is on, will the inverter wire work as Neutral and draw current towards it ?? Do Inverters have such a mechanism in their microcontroller ?
  2. Ramussons
    May 3, 2013
    562
    92
    No.
    But what do you have in mind?
    Ramesh
