inverter circuit?
Discussion in 'General Electronics Chat' started by ahmedahmedahmed, Dec 25, 2008.
  1. ahmedahmedahmed
    Nov 12, 2007
    29
    Hi everyone
    I need a circuit diagram for inverter which convert from 12vdc to 220 vac.
    and another one for 6vdc to 220 vac
    I need them simple with sinewave
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    How much power must they supply? - that is the hard part.
  3. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    You really should have put this with the other thread. He defined 7W in the first thread.
    Sine wave invertors are not simple. You don't need it anyhow for a flourescent, and most comercial models aren't sine wave either. Like I said, a simple 555 oscillator with a transistor booster feeding a transformer would do it.
  5. tanzeel
    Dec 31, 2008
    Hi
    this is a 500W inverter, but squere wave. after transfarmar the wave shape is near to signe wave.
    Try it...... :)
  6. eblc1388
    Nov 28, 2008
    1,542
    102
    The circuit uses a 10A input fuse for 12V battery supply.:confused:
    For a 500W inverter, at least a 50A fuse is needed.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    Not with a 10A fuse it isn't. 12V X 10A = 120W max.
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    You beat me to the post this time grasshopper, but next time it will be mine!
  9. Audioguru
    Dec 20, 2007
    9,411
    896
    It is an old square-wave inverter.
    The millions of parts making the oscillator can be replaced by a CD4047 IC one resistor and one capacitor.
