inverter circuit using mosfets
SgtWookie
Joined Jul 17, 2007
22,230
Jayashree95,
You are "hijacking" another members' thread. This is considered bad manners, it causes chaos/confusion, and it makes extra work for our Moderators.
If you wish to ask for help on an inverter, then start your own topic, and post your requirements, including input and output voltages, AC or DC (both sides) and current or power output and if AC, the frequency.
Wendy
Joined Mar 24, 2008
23,421
The OP has another thread on a similar subject,
555 timer inverter
To meet the requirements you state (220VAC, 1A) it will be 220watts, provided by the 12VDC source. For 12V this works out to 18.3 amps, which assumes 100% efficiency (not possible). You will find this is an unrealistic requirement for most batteries, a bank of batteries might do it.
Again, you need to tell us what you will be providing the power for. A square wave is not exactly suitable for most applications.
