Trying to find some info on the net, but can't see anyone who gives a clear answer on this:
Question is:
I want to have a system whereby it is permanently connected 24/7, and switches over to battery power during a power outage
Instead of connecting a UPS to a battery for power outages, can one connect a separate charger and inverter to the same battery?
If my logic serves me right, this would mean the following would happen:
1) Inverter would run constantly (with fan noise) as it is constantly converting from 12V to AC power
2) Charger would run constantly (unless power is out) as it is always topping up the battery due to constant use from the inverter
Surely this would be a highly inefficient setup, as it involves AC power -> 12V DC -> back to AC constantly.
As opposed to a UPS which bypasses inverter mode and pulls directly from AC when there is power?
Is the above correct? If so, then I guess a proper UPS would be the correct way to go?
Thanks for the help!
Question is:
