Inverter 12 volts DC to 240 volts DC
Discussion in 'The Projects Forum' started by Lightfire, Mar 22, 2011.
  1. Lightfire
    Oct 5, 2010
    690
    21
    I am wondering about an inverter or converter. :) It's a DC to AC converter. :)
    I am wondering if how many hours can it run appliances. :)
    Some of my friends says that it can only run for an hour if there's a lot of appliances.
    So guys, do you think, how many hours it can run some appliances approximately?
    Thank you!
  2. wayneh
    Sep 9, 2010
    12,374
    3,226
    The answer depends on the battery - how much power it can deliver before it discharges to a level requiring recharge - and the load's power demand. In addition to the load, the inverter itself will waste a bit of power in making the conversion. So to operate an appliance at 100W for an hour, your inverter might add 20W and you would need a battery that can supply 120 watt-hours of power. Note that your inverter must be rated at a power level high enough to handle whatever load you have.
