invert voltage for motor spin direction
Discussion in 'The Projects Forum' started by jaskiewiczm, Nov 20, 2010.
  1. jaskiewiczm
    Nov 1, 2010
    I've got an old motor that I salvaged from a busted CD-ROM drive. If I hook up the battery one way, it spins forward. If I reverse the battery, it spins the other way.
    I figured that I could use 4 transistors to flip the direction of the current but I was wondering is there a simpler way?
    Thanks,
    mj
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You could use a DPDT (double-pole, double-throw) switch, like this:
    You'd be best served to get a switch that has a center-off position. Suddenly reversing a motor by flipping it's polarity is very hard on it.
  3. jaskiewiczm
    Nov 1, 2010
    I forgot one additional detail :)
    I plan on buying a gumstix computer on module that I want controlling this thing. Aren't DPDT switches flipped by hand?
    Thanks,
    mj
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  5. debe
    Sep 21, 2010
    955
    185
    You could use these they are motor H drives from old VCRs very easy to use & cost nothing if you salvage them from old machines. Daryl
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  7. jaskiewiczm
    Nov 1, 2010
    Thanks!
    Two questions though.
    Why are the resistors necessary as inputs into the transistors?
    Also, what are those symbols at the top that look like a stylized "S"?
    mj
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You're referring to the schematic on this page: http://www.solarbotics.net/library/circuits/driver_4varHbridge.html
    Did you read the text?
    Current to the base of a transistor almost always has to be limited via some means when the transistor is used as a saturated switch.
    Without the resistors, it won't work at all.
    Those are symbols representing hysteresis, or a Schmitt trigger. A 74HC14 is a hex Schmitt-trigger inverter.
