Inverse Laplace Transform
Discussion in 'Homework Help' started by jegues, Feb 19, 2014.
  1. jegues
    Sep 13, 2010
    735
    43
    Evening gents,
    Can someone explain to me how,
    \Delta f(s) = \frac{-K}{1+sT} \Delta P_{d}(s)
    becomes
    \Delta f(t) = -K (1-e^{\frac{-t}{T}})|P_{d}(t)|
    when removed from the Laplace domain.
    I would have expected the following result,
    \Delta f(t) = \frac{-K}{T} e^{\frac{-t}{T}}P_{d}(t)
    I'm guessing maybe there was an initial condition imposed such that,
    \Delta f(t=0) = 0
    Any ideas?
  2. shteii01
    Feb 19, 2010
    3,518
    515
  3. WBahn
    Mar 31, 2012
    18,093
    4,920
    What's the relationship between the function ΔP_d and the function P_d?
    In the s-domain you have two functions multiplied together. When you take the inverse Laplace transform that ends up being convolution in the time domain.
  4. blah2222
    May 3, 2010
    565
    33
    Working backwards:
    <br />
<br />
\Delta f(t) = -K|P_{d}| + K|P_{d}|e^{-\frac{t}{T}}<br />
<br />
    Transforming to S-Domain:
    <br />
<br />
\Delta F(s) = \frac{-K|P_{d}|}{s} + \frac{K|P_{d}|}{s + \frac{1}{T}}<br />
<br />
\Delta F(s) = \frac{-K|P_{d}|}{s} + \frac{TK|P_{d}|}{1 + sT}<br />
<br />
\Delta F(s) = \frac{-K|P_{d}| - sTK|P_{d}| + sTK|P_{d}|}{s(1 + sT)} = \frac{-K|P_{d}|}{s(1 + sT)}<br />
<br />
    By this logic and assuming |P_d| is a constant I can only assume that Δf is some sort of step response to a given step function P_d(t), though the Δ notation is somewhat confusing.
