I am new fairly new to C++ and i'm having problems Initializing the required resisters needed for my project on motor speed control. I have used the data sheet(link below) but cannot get around the problem.http://ww1.microchip.com/downloads/en/devicedoc/41303g.pdf
The two problems I am encountering
interrupts not occurring. Code for interrupts process is below
when I enable global interrupts i.e. 'INCONbits.GIE =1' nothing displays on the pic (leds and screen) as if it where in sleep mode.
Initialization.
Interrupt Service
Initialization.
Rich (BB code):
void InitializeSystem(void)
OSCCON = 0b01110000;
OSCTUNEbits.PLLEN = 0; // turn off the PLL
// Setup I/O Ports.
ANSEL = 0x00; // all digital check if needed*
TRISA = 0; // TRISA outputs
LATA = 0b11110000; // drive PORTA pins low
oled_res = 1; // do not reset LCD yet
oled_cs = 1; // do not select the LCD
TRISB = 0b11111111;
LATC = 0b00101000;
TRISC = 0b00000000;
TRISD = 0; // TRISD is LED output
LATD = 0; // turn off LEDS
TRISE = 0b00000111;
// Set up global interrupts
RCONbits.IPEN = 1; // Enable priority levels on interrupts
INTCONbits.GIE = 1;
INTCONbits.RBIE = 1;
INTCONbits.RBIF = 0;
//configure buttons
WPUB = 0b00001111;
INTCON2bits.RBPU = 0; // turn on weak pull ups for RB0-RB3
INTCONbits.INT0IF = 0; // clear RB0 INT
INTCONbits.INT0IE = 1; // enable RB0 INT
INTCON2bits.INTEDG0 = 0; // interrupt on falling edge
INTCON3bits.INT1IF = 0; // clear RB1 INT
INTCON3bits.INT1IE = 1; // enable RB1 INT
INTCON2bits.INTEDG1 = 0; // interrupt on falling edge
INTCON3bits.INT2IF = 0; // clear RB2 INT
INTCON3bits.INT2IE = 1; // enable RB2 INT
INTCON2bits.INTEDG2 = 0; // interrupt on falling edge
// Setup TMR1
// Configure Timer 1
T1CON = 0b11111101;
INTCONbits.TMR0IE=1;
INTCONbits.TMR0IF=0;
INTCON2bits.TMR0IP=0;
// Configure MSSP for SPI master mode
SSPCON1 = 0b00110010; // clock idle high, Clk /64
SSPSTAT = 0b00000000;
PIR1bits.TMR1IF = 0;
PIE1bits.TMR1IE = 1;
OSCTUNEbits.PLLEN = 1; // Puts the PIC at 64MHz
CCP1CON = 0b00001100;
PSTRCON = 0b00010001;
// setup timer 2 for pwm
T2CON = 0b00000111;// Prescale = 1:16, timer on, postscale not used with CCP module
PR2 = 255; // Configure the Timer2 period
TRISCbits.TRISC2 = 0; // Make CCP1 pin as output
CCP1CON = 0x0C; // Configure CCP1 module in PWM mode
T2CON = 0x01; // Set Prescaler to be 4, hence PWM frequency is set to 4.88KHz.
T2CON |= 0x04; // Enable the Timer2, hence enable the PWM.
SetPWMDutyCycle(pwm); // Intialize the PWM to 0.5 duty cycle
} // end InitializeSystem
void SetPWMDutyCycle(unsigned int DutyCycle) // Give a value in between 0 and
// 1024 for DutyCycle
CCPR1L = DutyCycle>>2; // Put MSB 8 bits in CCPR1L
CCP1CON &= 0xCF; // Make bit4 and 5 zero
CCP1CON |= (0x30&(DutyCycle<<4)); // Assign Last 2 LSBs to CCP1CON
Rich (BB code):
#pragma code InterruptVectorLow = 0x18
void InterruptVectorLow (void)
_asm
goto InterruptServiceLow //jump to interrupt routine
_endasm
//----------Interrupt Service Routine-------------------------------------
#pragma interrupt InterruptServiceHigh
void InterruptServiceHigh(void)
if(INTCONbits.RBIF)
if(PORTBbits.RB6!=0)
UpperCounter++; //increment UpperCounter if RB6 goes high
speed_counter++; // increment the counter used to calculate
//speed
LATDbits.LATD7=~LATDbits.LATD7; // LED7 changes state each
//rising edge
Delay10TCYx(1);
else if(PORTBbits.RB7!=0)
//count pulses from ch B
LowerCounter++; //increment LowerCounter if RB7 goes high
speed_counter++;
LATDbits.LATD0=~LATDbits.LATD0; //LED0 changes state each
//rising edge
Delay10TCYx(1);
else if(PORTBbits.RB5 != 0)
//count pulses from ch Z
LowerCounter=0; //reset LowerCounter
UpperCounter=0; //reset UpperCounter
Delay10TCYx(1);
#pragma interruptlow InterruptServiceLow// "interruptlow" pragma for low priority
void InterruptServiceLow(void)
if(INTCONbits.TMR0IF)
position2=speed_counter;
speed=((((position2-position1)/64)*60)/2.1);
//calculate speed. TMR0 on 16bit prescalar1:8
TMR0H = 0;
// clear timer - always write upper byte first
TMR0L = 0;
INTCONbits.TMR0IF = 0;
// clear (reset) flag
LATDbits.LATD2=~LATDbits.LATD2;
position1=speed_counter;
