Interpreting a data sheet...
Discussion in 'General Electronics Chat' started by Externet, Feb 11, 2016.
  1. Externet
    Thread Starter AAC Fanatic!
    Nov 29, 2005
    775
    57
  2. Lestraveled
    May 19, 2014
    1,957
    1,217
    @Externet
    Higher resistance = higher gain
    Figure 3. The volume control pin outputs a current (70 micro-amps). The resistor to ground sets the voltage which controls the gain, Figure 3.
  3. Externet
    Nov 29, 2005
    775
    57
    Thanks. How did you find that ?
  4. Lestraveled
    May 19, 2014
    1,957
    1,217
    It wasn't spelled out. I started with Fig.3 and backed it out.
  5. hp1729
    Nov 23, 2015
    2,085
    232
    Which resistor in figure 7 are you talking about?
  6. Externet
    Nov 29, 2005
    775
    57
    ¿? -- The only one shown on figure 7 and pertinent to gain.
  7. hp1729
    Nov 23, 2015
    2,085
    232
    Lower resistance = lower gain. I think gain is more related to voltage in from the pot. Using a different resistance pot will give the same gain. But as the slider moves down the pot (lower resistance) you get lower gain.
