Interpretation of LCD + A-D CONVERTER connexions
Discussion in 'The Projects Forum' started by Johann, May 7, 2007.
  1. Johann
    Thread Starter AAC Fanatic!
    Nov 27, 2006
    190
    30
    Hi all!
    I have bought one ICL7106CPL (A-D converter + 3.5 digit LCD driver I.C.) Also, I've bought a VI-303-DPFC (3.5 digit LCD display unit).
    The data sheet for the ICL 7106 CPL is fairly clear to me. The info on the LCD is a bit confusing, because I am not absolutely sure how to connect the IC to the LCD.
    Oh yes, forgot to say that I need to make a panel meter that can read and display DC volts in the range 0 - 40V.
    Anyone with a wire-for wire explanation for me please? Which pin is the decimal point, for instance?
    Thanks!
    Johann
  2. mozikluv
    Jan 22, 2004
    1,437
    do you have the datasheet for your lcd? pls. post so we also can read.
    moz
  3. Johann
    Nov 27, 2006
    190
    30
    Thanks mozikluv! A little patience plse, I just want to make sure how to post it. Will come back soon.
  4. Johann
    Nov 27, 2006
    190
    30
    Here we go! Thanks!
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Connect C1 to 1C, connect D1 to 1D, etc.
    Decimal points of the LCD are pins 8, 12, and 16.
  6. Johann
    Nov 27, 2006
    190
    30
    Thanks, thingmaker3, better to be safe than sorry! Now everything seems simple enough!
    All the best.
    Johann:)
