how to include method interpolations for microcontroller for control motor servo ?? i need formula to methot interpolations.. i need disperately to help.. thanks
risky
risky
Interpolation formulas are included in any college algebra text.how to include method interpolations for microcontroller for control motor servo ?? i need formula to methot interpolations.. i need disperately to help.. thanks
risky
ok..thanks for your answer...a formula interpolations combined with progam servo motor.. do you help me.. i need flow chart diagram because i still confused for combinations..Interpolation formulas are included in any college algebra text.
Top Google Hit:
http://en.wikipedia.org/wiki/Linear_interpolation
I don't understand what you want to do. To control a servo motor you compare the command position to the feedback position and apply the error signal as the servo command. I don't see what interpolation has to do with controlling a servo motor. Maybe you could explain it to a poor controls engineer who just retired after half a century of doing this stuff.ok..thanks for your answer...a formula interpolations combined with progam servo motor.. do you help me.. i need flow chart diagram because i still confused for combinations..
i will make a trainer water level control there are 2 different tank layout its height. A tank (the top) to supply water to the tank bottom (b) by opening the water faucet using servo motors. filling of the tank bottom is determined by entering the input waktu.proses closing of the door water faucet on slowly perfect by comparing the value of the water .. the point is below the water level can be in control of servo motor angle and volume can be determined by entering input value as a reference..method interpolations used as method reduce error reading sensor ultrasonic.I don't understand what you want to do. To control a servo motor you compare the command position to the feedback position and apply the error signal as the servo command. I don't see what interpolation has to do with controlling a servo motor. Maybe you could explain it to a poor controls engineer who just retired after half a century of doing this stuff.
im sorry..im heaving difficulty expressing in english..because im just know english language.. I've tried to interpret from my language into English..I will try to learn english.my first language is java language.. so what method suitable for water level controll above?So you have an ultrasonic sensor whose readings are subject to more error than is acceptable. I'm sorry, but no interpolation method that I am familiar with is going to do anything to help you reduce the error of your sensor readings. Where do such such ideas come from? Did someone tell you this was an appropriate solution or did you think this up on your own? Perhaps you are confusing us by choosing the word "interpolation" when you actually mean another word. I'm sorry that you're having difficulty expressing yourself in English, but your English is clearly better than my...whatever your first language is.
ok max..thanks for your answer...From my career in CNC and Motion control, my definition of interpolation indicates a specific control of two or more servo motors to follow or create a precise trajectory path, two or more servo's that do not interpolate are considered a point-to-point system.
Max.
This would be the language spoken on the island of Java in the country of Indonesia, and not the computer language Java. Now I am certain that your English is better than my "language of Java".im sorry..im heaving difficulty expressing in english..because im just know english language.. I've tried to interpret from my language into English..I will try to learn english.my first language is java language.. so what method suitable for water level controll above?
Are you asking for a method to smooth or to filter the data samples from the ultrasonic sensor in some fashion, so that your control system will not be constantly opening and closing the valve as the errors appear in the data. The answer is yes there are methods to do this. You should do research on "Smoothing Algorithms" and "Filtering Algorithms".
Is your control of flow rate from upper tank to lower tank intended to be proportional or ON/OFF?
oke tanks for your annswerMy intention was that you would use Google or other textbook resources to find additional information about smoothing and filtering algorithms.
http://lmgtfy.com/?q=Smoothing Algorithms
http://lmgtfy.com/?q=Filtering Algorithms
Let us know how it works out for you.oke tanks for your annswer
ok..I will be draw a graph and how it works. wait a few minutes. because I need to interpret it in English. description of this toolLet us know how it works out for you.
First we must define the output parameters. the sampling volume and the maximum time is needed and the minimum time needed to fill the entire tank (b). after specifies parameters taken from the sample then the tool is ready in useLet us know how it works out for you.
by Duane Benson
by Aaron Carman
by Jerry Twomey
