Internal Resistance
Discussion in 'Homework Help' started by paulmc, Aug 13, 2006.
  1. paulmc
    Aug 1, 2006
    9
    just wondering if anyone could help me with Q3E . i dont know how the voltage would be measured. any help would be great thank you
    • Q3.doc
      File size:
      28.5 KB
      59
  2. paulmc
    Aug 1, 2006
    9
    could someone pls convert this file into pdf formate. or better show me how to do it. thank you
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Here you go paul.
    hgmjr
  4. BladeSabre
    Aug 11, 2005
    105
    I've been using CutePDF.
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Have you attempted this question yourself? If so please put them up, it is easier for people/people are more inclined to provide you with assistance if your attempts are posted.
    Dave
  6. paulmc
    Aug 1, 2006
    9
    3B} vAB=1.274v
    3C}GOT THAT ONE CORRECT
    3D} HER VOLT METER WILL MEASURE 0.9267V
    3E} I HAVE NO IDEA HOW TO DO THIS ONE SO IF ANYONE COULD HELP !!!!!!!!! THANK YOU
  7. Rail Ranger
    Member
    Aug 22, 2006
    15
    have you tried redrawing the circuit in it's simplest form? the series-parallel circuit can be redrawn to be a series circuit, then the math is easy after that.
    you could begin furthest away from the voltage source and redraw the parallel portions to series and make your math simpler.
    just a thought
  8. JoeJester
    Apr 26, 2005
    3,402
    1,227
    Q3E) Draw the circuit showing clearly how she could adapt her meter
    connection, using a device or circuit taught in the lectures, to measure the​
    correct value of V
    AB.
    What were you taught in the lectures?
  9. The Electrician
    Oct 9, 2007
    2,301
    339
    I don't get 1.274v for vAB
    Does your book say that's correct?
