For the second time in two years the switching power supply to my 14 year old microphone preamp is not passing power.
No rail voltage is present. Thinking the bridge rectifier may be bad, I replaced it. Still no rail voltage. I've searched for faulty diodes and found none to be bad. Today I decided to check primary voltage at the transformer. I powered up the board and, to my surprise, I now have power at the output pins.
Is there a particular component that would allow a power supply to work well for a time period, completely shut down for a period and then begin working properly?
I've attached a schematic for a similar IPD power supply. Mine was custom built by IPD for the application and has +29V, -29V and +52V outputs.
Thanks for you help,
mrvo
mrvo
