intergrated circuit (ic) measurement
Discussion in 'Electronics Resources' started by zogoman, Feb 21, 2011.
  1. zogoman
    Jan 19, 2011
    please could someone help me to know how can i realize that an ic has malfunction or in short how can i measure an ic
  2. nerdegutta
    Dec 15, 2009
    2,565
    805
    What kind of IC?
    What are you expecting it to do?
    Do you have a schematic?
    Do you have a circuit?
    Pictures?
    It will be so much easier if you provide these things, and more...
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    This is a very old skill called troubleshooting, where you look at the signals in, signals out, and try to figure out what could cause what you are seeing.
    Op amps and digital are usually pretty easy, since the results are not ambiguous. It is always possible something connected to the output pin is dragging it around, you just have to look and see, and sometimes remove other components to eliminate possibilities.
