Interference Lab(Filter)
Discussion in 'Homework Help' started by bham1307, Oct 7, 2008.
  1. bham1307
    Oct 2, 2008
    Design a circuit to filter 100 kHz and pass 2 KHz. The test circuit should contain a 2 KHz oscillator, a 100KHz oscillator, a filter circuit, and a 6 dB amplifier circuit.
    Basically I need to create a low pass or bandpass ciruit to pass the desired frequency and reject the other. I originally went with a bandpass circuit. I am really confused to be honest though, and need some help getting started
  2. mik3
    Feb 4, 2008
    4,846
    63
    Do you want to make a passive filter (use inductors, capacitors and resistors) or an active filter (use op-amp, resistors and capacitors)?
  3. bham1307
    Oct 2, 2008
    I need to creatve an active filter, using op amps(741 op amp)
  4. mik3
    Feb 4, 2008
    4,846
    63
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The good news is that the 741 has such a poor response that you won't need much of a filter to eliminate the 100KHz.
  6. bham1307
    Oct 2, 2008
    Thanks, this site was very helpful helping me get my correct values. The project is due thursday, so i may be in touch some tomorrow, after talking with my instructor. Thanks again!
  7. mik3
    Feb 4, 2008
    4,846
    63
    Beenthere, i like your point of view about how to use the 741 as simple low pass filter.
