interference and ne555 and relays
Discussion in 'Digital Circuit Design' started by bend94, Jul 5, 2016.
  1. bend94
    Feb 15, 2016
    14
    Hi everyone,
    i did a first circuit with Timer NE555 managing a relay1.
    i did another circuit with another relay2.
    all is working well except in this case :
    when relay1 is on (Timer555 is running) and relay2 is on. If i put relay2 off , the NE555 seems to reset the timer as a result the relay1 become off.
    Someone can help ?
    Regards
  2. AlbertHall
    Jun 4, 2014
    2,282
    450
    Do you have a catch diode across the relay coils?
    Do you have a decoupling capacitor across the NE555 supply terminals very close to the IC?
    Do you have a decoupling capacitor on the NE555 control voltage, pin 5?
  3. DickCappels
    Aug 21, 2008
    2,780
    675
    What is the relationship between the two relays? Please post a schematic diagram or at least a wiring diagram.
  4. bend94
    Feb 15, 2016
    14
    Well on the relay board there is a diode.
    what is a decoupling capacitor .? have you got an scheme example ?
  5. AlbertHall
    Jun 4, 2014
    2,282
    450
    You should have a capacitor, say 100nF, from pin 5 to ground, and also between pins 8 and 1 (the chip supply voltage)
    Also, the reset pin, 4, should not be left floating. If unused it should be connected to supply.
