interfacing with a temperature sensor
Discussion in 'The Projects Forum' started by mahmoudathab, Jun 4, 2013.
  1. mahmoudathab
    May 20, 2011
    24
    I have absolutely no experience with temperature sensors. I am interfacing with a STLM20 temperature sensor, the datasheet can be found here:
    http://www.st.com/web/catalog/sense_power/FM89/SC294/PF129199
    anyway the connection is quite simple, I have a question regarding the transfer function.....what is it and how can I use it to measure temperature?
  2. wayneh
    Sep 9, 2010
    12,374
    3,226
    The datasheet is pretty clear. What part do you not understand?
  3. mahmoudathab
    May 20, 2011
    24
    how to use the transfer function provided to measure temperature?
  4. wayneh
    Sep 9, 2010
    12,374
    3,226
    y = mx + b
  5. tracecom
    Apr 16, 2010
    3,878
    1,396
    Look at Table 2 in the datasheet. Pick the temperature range that best fits your application. Use the corresponding conversion formula.
    Or better yet, use an LM35 or LM34...much simpler.
  6. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Yep, LM35. Each 10mV = 1 degree C.
    It doesn't get much better than that.
  7. wayneh
    Sep 9, 2010
    12,374
    3,226
    I agree, 10mV per °C is so much easier that 11.77mV per °C. You can just measure voltage with a cheap DMM and you're done.
    I do see one advantage to the OP's chip - it can use a single supply over a much wider temp range.
