Interfacing wavecom M1306B GSM problem
Discussion in 'Embedded Systems and Microcontrollers' started by aamirali, Aug 6, 2014.
  1. aamirali
    Feb 2, 2012
    415
    I am interfacing wavecom M1306B & facing some problem.
    1. Sometimes when I send a command like "AT\r", I don't get any response from wavecom.
    Even if had 2 sec timeout for reception, after which I resend command but still don't receive anything from wavecom.
    2. I have only used rx & tx lines of wavecom. do wavecom needs all pins of uart for interfacing like CTS, etc.
    Edit:
    When I connect it to PC & use teraterm it works fine. I don't know if teraterm is using all pins of DB9. Buy CTS bit in teraterm shows green flag
  2. aamirali
    Feb 2, 2012
    415
    Datasheet says we have to use flow control:hardware.
    But I have triedin hyperterminal without flowcontrol i.e None, it works fine.
    Should I ground CTS pin of modem to ground. There is 7V coming there.
