interfacing (switches) in assembly language
Discussion in 'Programmer's Corner' started by zacknie, Feb 12, 2011.
  1. zacknie
    Jan 26, 2011
    9
    hello,
    im making a two button transaction queuing (1-99).,it is display on seven segment display... the problem is i don't know the code of inputting and debouncer.. i already know the pins of parallel port,.. BTW, im using a FASM..
    Tnx!!:)
  2. TierOne
    Feb 5, 2011
    16
    Inputs:
    MOV P0, AX
    ANL AX, 01H
    JZ debouncer
    debouncer:
    MOV P0, AX
    ANL AX, 01H
    JZ debouncer
  3. zacknie
    Jan 26, 2011
    9
    tnx sir!.. ill try this one... i will post here the result of your code..
