Interfacing SRAM memory with PIC18F87j11
Discussion in 'General Electronics Chat' started by hn123, Sep 13, 2012.
  1. hn123
    Sep 1, 2012
    hi,
    i am design one simple Circuit which i wants to interface SRAM with My PIC controller.
    I already used for it some logic IC 74CH138 & 74CH373 .and I used IS61LV256AL.last one is memory IC.
    I interface this but still i have some problem with control pin .
    I attached here with my schematic with my this post.
    Please guide me for this.
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Can you post your schematic as pdf. I can not open it
  3. Dodgydave
    Jun 22, 2012
    5,141
    767
    no files will open .sch files ???
  4. hn123
    Sep 1, 2012
    hi,
    its a file of Kicad Software
  5. t06afre
    May 11, 2009
    5,939
    1,222
    That does not help me at all. Please post your schematic in a format that is esy to read for all Like pdf or png
  6. ErnieM
    Apr 24, 2011
    7,435
    1,625
    Even using Kicad your schematic does not open properly. A Kicad sxchematic depends on the libraries it was created with.
    It is always best to show your example in a format that requires no special additional files or programs.
    It seems the data comes direct from the PIC, and the full 16 bit address comes from an 8 bit port where the high byte is latched by the 74LS373. It's not clear what the intent of the 74LS373 is, that's a rather large chip for one bit in and one bit out.
    What is your method for controlling WE OE and CS on the memory?
