Interfacing PIC16F1936 to IR2110 for three phase full bridge driving
Discussion in 'Embedded Systems and Microcontrollers' started by jean120, Jan 24, 2016.
  1. jean120
    Jan 24, 2016
    75
    Hello everybody,I am designing a three phase full bridge with PIC16F1936 and then need to control the six MOSFET/IGBTs I used IR2110 but I am not succeeding because the drivers(IR2110) are becoming hot and then burnt,the PIC also is having problems up to the damage,could you please help?
    the IR2110 is connected as the following link shows:
    http://tahmidmc.blogspot.com/2013/01/using-high-low-side-driver-ir2110-with.html
    the two MOSFET of the same branch are controlled by one driver.
    Please help to handle.Thank you!!
  2. dannyf
    Sep 13, 2015
    2,196
    417
    You gave so little information that it is impossible to help you.
    In general, you will need to generate 3 pwm pulse trains, with programmable deadtime, fully synchronized. You will need to check if your PIC can do that in hardware first. If not, you will need to figure out a way to do it in software - doable but with limitations on the pwm frequency.
    If the above makes no sense to you, the project isn't for you.
  3. Dodgydave
    Jun 22, 2012
    5,154
    772
    Are you trying to rectify a 3phase signal to DC,if so are you using Thyristors, or are you making a 3 phase signal from a DC psu?
  4. jean120
    Jan 24, 2016
    75
    Hello,I rectified a three phase and this gives DC Voltage of around 400VDC,and then this is used for supplying a three phase full bridge made using 6 IGBTs.Those IGBTs are controlled by a PIC16F1936 microcontroller which generates a SPWM signal and then before applying to the gate of an IGBT/MOSFET I used IR2110 as driver (with those drivers I now have a problem)!!
    Dear Dodgydave,with 3 PWM,how by using IR2110,the three phase full bridge can be controlled?Is the IR2110 work like IR2109(with this when you input one signal it outputs two syemmetric signals ).
    The PIC16F1936 I used,has the capability of generating the deadtime in software;I have configured the PIC16F1936 in half bridge using the ECCP so the P1A and P1B,P2A,P2B,P3A and P3B are used for controlling the three half bridge respectively.
