Interfacing pendrives with pic16f877a
Discussion in 'Embedded Systems and Microcontrollers' started by jaswanth666, Dec 18, 2010.
  1. jaswanth666
    Oct 26, 2010
    Hello guys,
    i thought of doing a project to interface two pendrives with a microcontroller .
    i mean to copy files from on pendrive to files on other pendrive
    can u guys help me in in completing this project
    my basic idea is to make usb interface with pic and then continue with my project
    please help in choosing the components and tutorials based on interfacing,program help
    hoping u guys help in my project:):):):):):p
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    You need USB and that has to be the more complex USB host. USB host (OTG) is available in some PIC32MX microcontrollers.
  3. Markd77
    Sep 7, 2009
    2,803
    594
    It isn't going to be a walk in the park.
    If I understand right you need a PIC which can be a USB host, it's possible you might need (or it would be easier) with 2 of them.
    If you go here and click USB, then look in the USB column for OTG I think they are the ones you need. I think the ones that have device in the column can only be USB slaves so couldn't interface with the pendrive. There's a lot of documentation to read though on the site.
    (This is about the limit of my knowledge, I've never done any of this).
    http://www.microchip.com/productselector/MCUProductSelector.html
  4. t06afre
    May 11, 2009
    5,939
    1,222
    You could use a SD card, as a workaround. That will be much simpler. And a lot of samples out on the net
  5. maxpower097
    Feb 20, 2009
    795
    388
  6. R!f@@
    Apr 2, 2009
    8,785
    771
    I can't believe you bunch falling for OP to make him a pen drive duplicator.
    Are guys wiling to practically handed over a USB memory stick copier on the go to some Indian who may or may not be in the businesses of selling these kinda stuff, or OP may or may not try to steal unsuspecting individuals data with in a second or so.
    Think about it.
  7. maxpower097
    Feb 20, 2009
    795
    388
