interfacing pc to a 8051 micro controller
Discussion in 'General Electronics Chat' started by dawuzi, Apr 18, 2011.
  1. dawuzi
    Apr 11, 2011
    hi everyone. I would like to send three set of data from the 8051 micro controller to a c# application running on a pc with some control signals sort of identifying which data is been sent currently. i have not interfaced a pc to a controller before so please include little details as well.
  2. GetDeviceInfo
    Jun 7, 2009
    RS232 port if you have one.
  3. RiJoRI
    Aug 15, 2007
    Look around on There should be a load of code & schematics.
    You'll need to design a message format so the PC can figure which data set you are sending. Something like this:
    [Bytes in message][Data set number][data...][Checksum]
    Each [] is one byte. [data...] is a string of data bytes. Or 1 byte.
    Is there a reason you are using an 8051? An Arduino board may be easier. Or if your data is not coming in too fast, a Parallax BASIC Stamp may do the trick.
