Interfacing Of At89c51 With Adc0804
srinivasinc2003
Joined Nov 15, 2006
Please tell how to read ADC0804.
I m not able to get output in second programme at PORT2 ? Please help me.
/* PORT1 is interfaced with 8-bit output of ADC0804.
main()
while(1)
P2=P1;
main()
while(1)
if(P1<80)
P2=P1;
else
P2=0;
itspider
Joined Nov 4, 2006
6
ORG 00H
;P3.4 <-->WR(to start convert analog - binary (0804)we must have WR 0->1)
;P3.5 <-->INTR (=0 to and convert)
;P3.3 <-->RD (RD 1->0 to read data from ADC)
;P2 <-->D0-D7 (out put)
MOV P1,#0FFH ; to receive data from ADC
BACK:
CLR P3.4 ; WR =0
SETB P3.4 ; dat WR = 1 to start convert
HERE:
JB P3.5,HERE ; wait to end convert
CLR P3.3 ; end convert and allow read data form ADC
MOV A,P1 ; read data onto A register
ACALL CONV_ASC ; convert to ASCII and display
ACALL DISPLAY ; on LCD
SETB P3.3 ; dat RD=1 for read next steps
SJMP HERE ;
END
saha
Joined Jun 1, 2006
53
hello itspider,
I'd heard abt HO CHI Minh. BUT COULD YOU TELL ME WHAT THE FOLLOWING LINE MEANS, PLS EXPLAIN IN ENGLISH.
Không có việc gì khó.
Chỉ sọ lòng không bền
"Ho Chi Minh"
#define ADC_Data P1
#define ADC_RD P3.3
#define ADC_WR P3.4
unsigned char Read_ADC(void)
ADC_WR = 0;
ADC_RD = 1;
ADC_WR = 1;
DELAY();
ADC_RD = 0;
return ADC_Data ;
vid main()
while(1)
P2 = Read_ADC();
Mohammad
Joined Jan 4, 2007
hi
i m new here but i may can help you , i make a project of how to convet analog signal to digital using ( at89c51 , adc0804 ) and display the result into 7-segment the program is in assemply and it works good
if you interested i will send you the project.
tayyab03
Joined Feb 4, 2008
well i am having problems interfacing with microcontroller we are using adc0804 in free running mode ... while we sending ff at the p1 port ... all the pins of adc gets high .. so it dont deliver the data of its on towards the port1 of 89c51
plz help .. what can i do
Papabravo
Joined Feb 24, 2006
21,225
Clearly you have not connected and managed the ADC0804 control signals properly.
You need to activate Chip Select and Write to start a conversion.
You need to activate Chip Select and Read to read the result.
You need to carefully read the datasheet
http://cache.national.com/ds/DC/ADC0801.pdf
Chip Select (CS) is pin 1
Read (RD) is pin 2
Write(WR) is pin 3
Please check out the timing diagram on page 6 for starting conversion.
Please check out the timing diagram on page 7 for reading the result.
Please check out page 23, section 2.8 for free running mode. Did you momentarily force WR and INTR low after power up?
This is really an easy chip to work with.
tayyab03
Joined Feb 4, 2008
now what i have done is
p3.6 (WR)
p3.7 (RD)
p3.2 (INTR)
p1 (D0-D7)
org oh
mov p1,0#0ff
back: clr p3.6
setb p3.6
here: jb p3.2,here
clr p3.7
mov a,p1
setb p3.7
sjmp back
end
still its not working i dont have any idea y now it have to work can any one help ....
Papabravo
Joined Feb 24, 2006
21,225
Don't you need a chip select line?
Is 0xFF the command you need to start a conversion? Why do you not do this command on the subsequent conversions.
