interfacing of 3 digit 7 segment display
Discussion in 'Embedded Systems and Microcontrollers' started by lakshitgoyal, Aug 22, 2009.
  1. lakshitgoyal
    Jun 17, 2009
    hi everyone,
    Tell me which driver IC (like BCD to 7 segment latch) we should use to interface between AT89C51 (microcontroller) with 3 digit seven segment display (having 12 pin).
    Also how I can do switching with transistors with single port of microcontroller simultaneously when other main programmed is also running in the microcontroller.
    email id:- <snip>
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    Do you know the type of the display?
    A link to the datasheet would help.
    Is it CA or CC?
    Greetings,
    Bertus
  4. ranjithkh
    Aug 27, 2009
  5. srikanthsamaga
    Member
    Jul 1, 2008
    13
