Interfacing electronic circuit with computer
Discussion in 'General Electronics Chat' started by ragoth.pln, Nov 25, 2008.
  1. ragoth.pln
    Nov 25, 2008
    My project is in the field of Power Distribution System. . .
    I wish to know how i can control an electronic device using my comp/laptop. its just like sending START and STOP signal to that device to switch ON/OFF a circuit.
    Please help me with
    1. Which port to use(easy one pl) ?
    2. Where to get the driver ?
    3. Is the port compatible to be controlled using .NET platform ?
    pl guide me in this.. . .
    it ll be very helpful
    _________________
    With Regards Ragothaman
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Please refrain from posting mulitple times. Multiple postings cause confusion resulting in delayed replies by members.
    hgmjr (moderator)
  3. gotumal
    Mar 24, 2008
    99
    You can use any port like USB, LPT1, serial etc depending on the availability, speed, no. of loads, distance, etc. For LPT you will need least external hardware.
    2. Where to get the driver?
    Drivers will be available as libraries.
    Sure.
  4. gotumal
    Mar 24, 2008
    99
    Sure.
