Interfacing DS 1307 with PIC
Discussion in 'General Electronics Chat' started by RG23, Jan 27, 2011.
  1. RG23
    Thread Starter Active Member
    Dec 6, 2010
    301
    I am having a problem in setting the time data on RTC.
    I am able to read the data from RTC perfectly
    but the displayed time on LCD is not the actual time.
    I want to set the correct time and then read from RTC.
    If anyone has an idea please let me know
    Thank you
  2. RG23
    Dec 6, 2010
    301
    set_clock:
    ;movlw 0xC4
    ;movwf PORTD
    ;call SND_CMD
    movlw second-1 ; prompt user for data (month)
    ;call write
    call readbcd
    movwf SECS
    movlw minute-1 ; prompt user for data (month)
    ;call write
    call readbcd
    movwf MINS
    call RTC_brst_wr
    return
    RTC_brst_wr:
    call I2C_STRT
    movlw 0xD0
    movwf I2C_Value
    call I2C_SEND
    movlw 0x00
    movwf I2C_Value
    call I2C_SEND
    movf SECS,0
    movwf I2C_Value
    call I2C_SEND
    movf MINS,0
    movwf I2C_Value
    call I2C_SEND
    call I2C_STP
    return
    ;write:
    ;movwf SCRATCH1
    ;GoWrite:
    ;call pclsub ; advance pointer and read pointed byte
    ;addlw 0h ; if contents are zero, Z will be set
    ;btfsc STATUS,Z ; skip if clear
    ;return ; current character is null: end of string
    ;movlw 0xC4 ; print one character
    ;movwf PORTD
    ;call SND_DTA
    ;goto GoWrite
    ;pclsub:
    ;incf SCRATCH1,1 ; advance table pointer
    ;movf SCRATCH1,0 ; move table pointer to W
    ;movwf PCL ; jump to address pointed by PCLATH,W
    readbcd:
    clrf I2C_Value ; clear temp reg
    gobcd:
    ;call uart_getchar ; returns character in W
    ;call uart_putchar ; echo to screen
    ;movlw 0xC4
    ;movwf PORTD
    ;call SND_CMD
    ;movwf PORTD
    ;call SND_DTA
    xorlw 0x0d ; if cr, Z will be set
    btfss STATUS,Z ; skip if clear
    goto bcd ; go to bcd if Z = 0
    movf I2C_Value,0 ; done, move final value to W
    return ; and return
    bcd:
    xorlw 0dh ; restore value
    addlw -30h ; subtract ASCII offset
    btfsc W,4 ; jump if not A-F
    addlw -7 ; if A-F, subtract 7
    digit:
    andlw 0x0f ; clear upper nibble
    bcf I2C_Value,4 ; clear upper nibble of temp reg
    bcf I2C_Value,5
    bcf I2C_Value,6
    bcf I2C_Value,7
    movwf SCRATCH1 ; save W
    movf I2C_Value,0 ; copy TMP to W
    movwf TMP2 ; save TMP
    movf SCRATCH1,0 ; restore W
    movwf I2C_Value ; TMP now has org W value
    movf TMP2,0 ; W now has org TMP value
    swapf TMP2,0 ; swap nibbles
    iorwf I2C_Value,0 ; insert bits 0 to 3 of TMP to W
    movwf I2C_Value ; move W into temp reg
    goto gobcd ; continue until CR is encountered
  3. RG23
    Dec 6, 2010
    301
    above subroutine I used for writing min and sec to RTC
  4. jdraughn
    Jan 30, 2009
    33
    You are probably having trouble because it's in BCD format and you need to convert it to decimal so it makes sense. You also need to send it BCD when you write too it.
