Interfacing ADXL375 problem
Discussion in 'Embedded Systems and Microcontrollers' started by Vindhyachal Takniki, Dec 27, 2014.
  1. Vindhyachal Takniki
    Nov 3, 2014
    358
    6
    I have interfaced ADXL375 & I have some below. I have attached the code.
    1. The offset I am getting is huge.
    It is 1g approx on both x & y axis & 1.5g on z-axis.
    I don't know what could be problem. I read offset registers , they are all zero in ADXL375.
    I had read thread on Analog forum, someone gad same problem with offset +4G on z axis.
    He had removed the IC & resoldered new one & problem gone.
    But I wan't to know what could be exact reason?
    2. For ODR <= 800Hz, we multiply register value with 49 to get g value i.e:
    g = (register_value * 49)
    But when OCR = 1600 or 3200Hz, what is the factor.
    I had red in datasheet that in this case LSB is always zero. So what will be coversion factor or it will remain same = 49.
    3. I had calibrated the adxl375 by placing it in z = +1g & other axis = 0.
    But I have seen example in which calibrate in all six axis is done:
    https://learn.adafruit.com/adxl345-digital-accelerometer/programming
    But how to calculate final offset from these six offset values?
    Or should I take there average.
    4. Edit: I have been able to read DEV id properly & SPi speed is 3.75Mhz.
    Code (Text):
    1.
    2. #define ADXL_REG_DEV_ID          (0x00)
    3. #define ADXL_VAL_DEV_ID          (0xe5)
    4. #define ADXL_REG_PW_CTRL         (0x2d)
    5. #define ADXL_REG_INT_EN          (0x2e)
    6. #define ADXL_REG_INT_MAP          (0x2f)
    7. #define ADXL_REG_DATA_FM         (0x31)
    8. #define ADXL_REG_DATA_RATE       (0x2c)
    9. #define ADXL_REG_DATAX0          (0x32)
    10.
    11.
    12. void main(void)
    13. {
    14.     configure_adxl375();
    15.
    16.     while(1)
    17.     {
    18.         //take 100 samples & average
    19.         adxl_read_offset_values(&x_val , &y_val ,&z_val);
    20.         x_val *= 49;
    21.         y_val *= 49;
    22.         z_val *= 49;
    23.
    24.         //offset for x:1274 , y: 1225 , z:1597
    25.     }
    26.
    27. }
    28.
    29.
    30.
    31. void adxl_read_g_values(int16_t *x_val , int16_t *y_val , int16_t *z_val)
    32. {
    33.     uint8_t values[6];
    34.     uint32_t error
    35.
    36.     adxl_read_reister(ADXL_REG_DATAX0 , 6U , &values[0]);
    37.
    38.     *x_val = (s16_t)( ((u16_t)values[1] << 8U) | ((u16_t)values[0]) ) ;
    39.     *y_val = (s16_t)( ((u16_t)values[3] << 8U) | ((u16_t)values[2]) ) ;
    40.     *z_val = (s16_t)( ((u16_t)values[5] << 8U) | ((u16_t)values[4]) ) ;
    41. }
    42.
    43.
    44.
    45. void configure_adxl375(void)
    46. {
    47.     uint8_t data;
    48.
    49.     SPI_MODE(3);
    50.
    51.     data = adxl_read(ADXL_REG_DEV_ID);
    52.     if(0xe5 != data)
    53.     {
    54.         error_trap();
    55.     }
    56.
    57. /* power ctrl */
    58.     adxl_write(ADXL_REG_PW_CTRL , 0x00);
    59.     adxl_write_register(ADXL_REG_DATA_FM , 0x0bU);
    60.     adxl_write_register(ADXL_REG_DATA_RATE , 0x0dU);
    61.     adxl_write_register(ADXL_REG_PW_CTRL , 0x08U);
    62.
    63. }
    64.
    65.
    66.
    67. void adxl_write_register(uint8_t address , uint8_t value)
    68. {
    69.     ADXL_CS_ENABLE();
    70.
    71.     adxl_spi_byte(address);
    72.     adxl_spi_byte(value);
    73.     ADXL_CS_DISABLE();
    74.
    75. }
    76.
    77.
    78.
    79.
    80. void adxl_read_reister(uint8_t address , uint32_t no_bytes , uint8_t *values)
    81. {
    82.     uint32_t cnt;
    83.     uint8_t reg_add = 0x80U | address;      /* msb is high fro reading */
    84.
    85.     if(no_bytes > 1U)   /* for multi read bit 6 is also set */
    86.     {
    87.         reg_add = reg_add | 0x40U;
    88.     }
    89.
    90.     ADXL_CS_ENABLE();
    91.
    92. /* send address */
    93.     adxl_spi_byte(reg_add);
    94.
    95.
    96. /* sent bytes */
    97.     for(cnt = 0U ; (cnt< no_bytes) ; cnt++ )
    98.     {
    99.         values[cnt] = adxl_spi_byte(0xffU);
    100.     }
    101.
    102.     ADXL_CS_DISABLE();
    103.
    104. }
    105.
  2. Vindhyachal Takniki
    Nov 3, 2014
    358
    6
    1. Way I have done calibration now:
    I have take gain & offset errros into account.
    Took two readings in +x axis & -ve axis.
    Value at +x axis (1000mg) comes out to 1500mg.
    Value at -x axis(-1000mg) comes out to 789mg.
    From here I have calculated gain & offset error for x axis, by two point calibration.
    Similarly for other two axis.
    Is it correct method?
    2. Why so much error? Only thermal stress can produce so much error?
    3.
  3. Vindhyachal Takniki
    Nov 3, 2014
    358
    6
    1. If, ODR = 3200 then number of sampes I can take per sec is 1600 without aliasing right?
    2. What is the final g value from three axis. Is it:
    g = ( (x*x + y*y + z*z) ^ 0.5 ) / 3
    3.If I configure ODR = 3200 & not able to take sample at Data ready interrupt. Then does that mean new data will overwrite older data & 3 axis data read can be corrupted or whenever I read 3 axis data it is always reliable & current data?
    I read 3 axis data at once.
