Interfacing ADE7763 with 8051/8052
Discussion in 'Embedded Systems and Microcontrollers' started by JeffreyPeter, Jul 28, 2012.
  1. JeffreyPeter
    Jul 25, 2012
    10
    Is it possible to connect Ade7763 directly to 8051 ??
  2. ErnieM
    Apr 24, 2011
    7,442
    1,628
    If you can do an SPI interface then yes you can connect them.
    JeffreyPeter likes this.
  3. JeffreyPeter
    Jul 25, 2012
    10
  4. t06afre
    May 11, 2009
    5,939
    1,222
  5. MrChips
    Oct 2, 2009
    12,642
    3,457
    The ADE7763 uses an SPI interface. You can implement this on any mcu requiring only three connections, SCLK, DIN and DOUT. (CS' can be tied LOW.)
    If the mcu already supports SPI then the task is made a bit simpler.
