Interfacing a PNP sensor's output to an 8051 MCU
Discussion in 'Embedded Systems and Microcontrollers' started by cmartinez, Jan 9, 2016.
  1. cmartinez
    Thread Starter AAC Fanatic!
    Jan 17, 2007
    3,696
    2,747
    The AT89S8052's pins are configured as bi-directional input-outputs. The way I understand that they work is by weakly pulling up an internal drain terminal. They're capable of delivering very little current, they were designed to drain current instead. The datasheet does not say what resistor value is internally being used to pull the pin up.
    Anyway, I need to detect a signal level change on those bi-directional pins arriving from a sensor that has a PNP output (its high output level is 5V, so we're safe as far as voltage is concerned). My plan is to pull the MCU's pins down with a resistor, so that when the sensor is activated it will bring the voltage back up.
    I've tried to represent what I think is happening inside the MCU, and what I plan to do to interface it to the PNP sensor. I hope my depiction is more or less accurate.
    My question is, what's the maximum value allowed for those pull down resistors so that the MCU will detect a low signal at its pin? I'm under the impression that the higher, the better, so as to draw as little current as possible from the PNP sensor when it goes high.
    @Papabravo I have a hunch that you might be able to help me out with this one.
  2. GopherT
    Nov 23, 2012
    6,297
    4,019
    How can we tell you the max resistor value without knowing what the sensor is or access to the datasheet for the sensor.
    cmartinez likes this.
  3. Papabravo
    Feb 24, 2006
    10,338
    1,850
    The weak pullup is on the order of 40K Ohms, but this parameter is not specified. As I understand a PNP sensor it wants to have an active pullup to VCC and a passive pull down to ground. If we start with a nominal weak pullup of 40 KOhms and a desire to have the passive level at less than 0.1Vcc something like 2.2K might do the trick.
    2.2K / (40K + 2.2K) ≈ 0.052
    With a Vcc of 5V that will put the input low level at about 0.26V.
    Check the datasheet to see if this is still a guaranteed low. At 5V the 2.2K resistor will sink abut 2 mA which is not an excessive amount.
    Since the 40K value is not speced and is more likely to be higher than lower (from my experience) you should be good to go.
    To quote my favorite Republican, Ronald Reagan "Trust, but verify".
    Words to live and engineer by.
  4. cmartinez
    Jan 17, 2007
    3,696
    2,747
    Thanks GopherT for taking the time to respond. I think Papabravo might be right on target. Although the Atmel's MCU datasheet does not specify the internal resistor value, the 8051 architecture is quite old and is supposed to be more or less standardized between brands.
    I'm so glad you answered my post stating a recommended 2.2k value. I'll be installing those resistors and testing the circuit tomorrow, and they're SMT. I was planning on using 10K resistors, and being forced to dismount them after going through a headache trying to figure things out would've been a pain in the backside.
    You've saved the day (again). Thank you very much.
  5. Papabravo
    Feb 24, 2006
    10,338
    1,850
    You realize that I'm going to feel really really bad if you have to swap them for a different value. I guess I wish you hadn't told me that, but I'll cross everything that can be crossed and hope for a positive outcome. CVS (Chuckling Very Softly).
  6. GopherT
    Nov 23, 2012
    6,297
    4,019
    Just clip/crush the smd resistors in half and remove half at a time. Then put the new one in place.
  7. cmartinez
    Jan 17, 2007
    3,696
    2,747
    Boy, am I glad this is not a parachuting forum... :eek::)
    atferrari likes this.
  8. atferrari
    Jan 6, 2004
    2,663
    783
    What if you put a DMM in series to measure the current while pulling the node down?
  9. cmartinez
    Jan 17, 2007
    3,696
    2,747
    Yeah, I can do that. But better yet, tomorrow I'll connect a 50k pot configured as a rheostat to one of the mcu's pins and make a tiny program instructing another pin to go low (monitoring it with a dmm, of course) when a low signal is detected in the first pin.
    That way I'll know exactly what resistance is needed to pull the pin down. And then I'll use half that value as a safety measure.
  10. Picbuster
    Member
    Dec 2, 2013
    391
    53
    The question is simple: max output sensor =5V as stated.
    forget about the week pull-up to high to disturb the lot.
    from mpu data sheet you know when a signal is declared high. assume 1Volt
    voltage dividers @ 5V 4:1 40K/10K if however the input should not go above the 3v3 then use a clamp diode to the 3v3 from mpu vdd.
    if the output of pnp sensor is current then follow procedure below to find value(s).
    Take a 27K in serie with this pnp sensor connect the lot to 5V activate sensor and read voltage over resistor.
    this will give you an indication for the divider.
    assume < threshold calculate the wanted value
    Assume 2.5V ready
    But try to use always a clamp to protect input when a mishap with sensor or wire happens.
  11. cmartinez
    Jan 17, 2007
    3,696
    2,747
    Just thought I'd drop by and let you know that I finally built the thing and tested it.... and it worked perfectly!
    You can stop chuckling now, and start smiling :)
    Thanks again!
  12. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Yea! Small victories always make me smile.
