interface
Discussion in 'General Electronics Chat' started by assassinelec, Mar 27, 2011.
  1. assassinelec
    Mar 22, 2011
    13
    hi all,
    i need to interface between an electrical circuit and a laptop, so i can take the signal into the computer via a serial port, is there any way to do it? or any interface available in industry i can buy it to do that, cuz am looking for it till now for two weeks and still can't find it, any help would be appreciated.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  3. assassinelec
    Mar 22, 2011
    13
    thanx for replying, but i still can't find it
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What signal are you trying to input?
    Does it have to be RS-232, as RS-232 has been on the way out for awhile now - USB, Firewire, and other interfaces have replaced RS-232.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
  6. assassinelec
    Mar 22, 2011
    13
    thanx really for replying, i finally found the interface circuit
    http://pdfserv.maxim-ic.com/en/an/AN827.pdf
    plz guys take a quick look on it, its a simple circuit but i have some trivial questions about the circuit
    -at the output (the PC serial port part) what does "D8-D9 CONN" means? , and what about the remaining bins in serial port (unconnected pins)?
    -what is the maximum acceptable frequency that can be processed by this circuit ?
    i really need some help in those questions am trying right now to find the answers...any help would be appreciated
  7. almoatazbellah
    Nov 24, 2010
    22
    the max. acceptable freq. is 37.5KHZ, but i dont know the first question
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The connector for RS-232 is usually a DB-9 connector, so called because it looks more or less like a "D" when looking directly at the pins or sockets, and has 9 pins or sockets. In the old days, it was a DB-25 connector.
    They are unused.
    That will depend upon your laptop's hardware. Some went up to around 115k baud. Some are limited to 9600 baud (roughly, bits per second).
    You will have to look at your hardware specifications.
    USB ports are far faster.
  9. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    Why not get an Arduino. It is overkill ( perhaps ) but is very general purpose and you would have a tool for many other projects. And since your project is so undefined, it might adapt to what you want. Most work out of the box with usb on most os's.
  10. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It seems that our OP wants to use RS-232. If they are running Windows, their RS232 performance will be pretty dismal.
  11. assassinelec
    Mar 22, 2011
    13
    @sgtwookie, thank u very much for replying, you were really helpful :)
