Interface LDR with micro controller without using a ADC.
Discussion in 'Embedded Systems and Microcontrollers' started by thar07, Feb 11, 2015.
  1. thar07
    Jan 3, 2015
    71
    Can LDR interface with a micro-controller without using a ACD ?
    TO use as a on/off switch which gives 0V and 5V s.
  2. Magician
    Aug 18, 2014
    13
    6
    Sure, you don't have to use ADC. Connect LDR with a resistor in series between power line and ground. Middle point goes to input of the uCPU. The problem is LDR has wide dynamic range, over 10^6, it's resistance change from ~100 Ohm in bright lighting condition to ~100 M Ohm in darkness. It's may be tricky to select right loading resistor
    thar07 likes this.
  3. BobTPH
    Jun 5, 2013
    806
    121
    Use a Schmitt trigger input if it is available on your micro controller.
    Bob
