Interesting things seen on eBay/Craigslist Thread.
Discussion in 'Off-Topic' started by GopherT, Jul 3, 2016.
  1. GopherT
    Thread Starter AAC Fanatic!
    Nov 23, 2012
    6,304
    4,027
    Anything you see that may interest other members - feel free to post.
  2. GopherT
    Nov 23, 2012
    6,304
    4,027
  3. wayneh
    Sep 9, 2010
    12,379
    3,234
    I'll post an example when I see one. The ones that make me chuckle are the guys trying to sell old tools as "vintage".
    That's code for "really old and worthless, but I can't part with it".
    GopherT likes this.
  4. tracecom
    Apr 16, 2010
    3,878
    1,396
    Is that why my wife says I am vintage?
  5. wayneh
    Sep 9, 2010
    12,379
    3,234
    Here's one small example. The saw doesn't look too bad until you get to the fine print.
    Vintage Craftsman Table SAW - $45
    This is a Vintage Craftsman table saw in great shape - does NOT come with a motor . This is Model # 113.22400
  6. tcmtech
    Nov 4, 2013
    2,110
    1,750
    I just picked up one similar to that and fully functional at an auction for $20. :D
  7. joeyd999
    Jun 6, 2011
    2,756
    2,923
    But it does come with a power cord. I wonder what that hooks up to?
  8. GopherT
    Nov 23, 2012
    6,304
    4,027
    Craftsman Table saws have a keyed switch with power cord connecting to either a plug or a junction box (older models). Replacement motors or alternate motors are easily mounted that way.
  9. #12
    Nov 30, 2010
    16,671
    7,317
    I have a very similar Craftsman table saw which I bought (new) in 1978.
    I have the 1HP motor that was attached in the first place, but I attached a 5HP motor and the proper power cord.
    Now it plugs into a clothes dryer outlet and splits an 8 foot (really) 1 inch by (really) 4 inch board in 20 seconds.
    Much better than the 100 seconds required with a 1 HP motor!!!
    My point is: You can attach any motor with a 4 bolt base plate.
    (I added a control transformer and 30 amp contactor so I wouldn't burn up the original power switch, intended for a 1 HP motor.)
    GopherT likes this.
  10. joeyd999
    Jun 6, 2011
    2,756
    2,923
  11. #12
    Nov 30, 2010
    16,671
    7,317
    Excellent way to contrast Tim Taylor's work to my work.
    joeyd999 likes this.
  12. GopherT
    Nov 23, 2012
    6,304
    4,027
    The Craftsman tools were really a great value. Not perfect for fine cabinetry but definitely designed for carpentry projects. With the big motor, the arbors and bearings were fine for up to 5HP motors.
    I completely believe the wood that you are processing. Just be careful that the blades don't buckle. Most consumer-grade blades are too thin for those feed rates.
  13. #12
    Nov 30, 2010
    16,671
    7,317
    As you can see, the fence is finished. Hundreds of wet, cypress 1x4's straight from the saw mill. Never had a problem with the feed rate because I was present at all times, pushing the board through with my hand and listening to the motor. I just don't see how one can have a problem with the feed rate when you're pushing the board with your hand.:confused:
  14. wayneh
    Sep 9, 2010
    12,379
    3,234
    Mine was free! But I probably watched the "tools" and "free stuff" listings for a year before scooping it.
    I'm a little embarrassed to show that it's being used as more of a TABLE saw than a table SAW, but not embarrassed enough to clear it off. ;)
    The dust enclosure below came with it. I built the crosscut sled on top.
  15. tracecom
    Apr 16, 2010
    3,878
    1,396
    Terrible waste of a nice looking '56 Chevy station wagon.
