First, before I get to the meat of the matter, this circuit has nothing whatsoever to do with automotive modifications, even though it contains high voltage ignition circuitry. It's also not designed, or used to shock people.
The circuit itself is used to ignite waste gas from natural gas drilling operations, and quite simply, delivers a high voltage spark at the top of a flare stack every 20 seconds, or so. If the drill hits a gas pocket, the gas is routed to the flare stack, where it can safely be burned off.
The problem I'm seeing is that the circuit is prone to failure, and out of nine igniters, I have four down for the same problem. The problem manifests itself with high voltages present throughout the circuit, which generally scrambles a pair of 555 timers. The device that's failing is a Fairchild [SIZE=-1]ISL9V5036P3, which states in it's datasheet that external components for protection are not required.
The collector of the device is connected to the primary of the ignition coil through a relay, without the use of any external protection components at all. The 'problem' first manifests itself by loss of consistent spark delay, duration and 120hz drive signal from the two 555 timers that control those functions. The chip also becomes very warm...too warm to even touch, by which point, the chip is fried.
My solution is to connect a suitably sized MOV from collector, to ground, which can be done easily by soldering the MOV on to the back of the circuit board. Which is about all I can do without removing the [/SIZE][SIZE=-1][SIZE=-1][SIZE=-1][SIZE=-1]ISL9V5036P3[/SIZE][/SIZE] and placing it on it's own daughter board.
Question: Since the MOV is going to be conducting on a regular basis in order to protect the ISL9V5036P3, can I expect premature failure of the MOV? The MOV I'm looking at is rated at 200 volts, 10 amps.
Thanks in advance, everyone! [/SIZE]
[/SIZE]
[/SIZE]
