Interesting grab bags in Maplin (Birmingham)
Discussion in 'Off-Topic' started by Markd77, Mar 8, 2012.
  1. Markd77
    Thread Starter Senior Member
    Sep 7, 2009
    2,803
    594
    I got a couple of these which were £2 each. I don't know if other branches are doing the same thing, I think these were the best bags (and there were only 2 exactly the same) but some of the bags looked pretty good too. Lots of the DC-DC converters in different values.
      File size:
      83.8 KB
      63
    Sparky49 likes this.
  2. Sparky49
    Jul 16, 2011
    835
    417
    I usually stay well clear of Maplins (I've been bitten by their cack attitude a few times), but I might just make an exception.
    Thanks for the heads up. :)
  3. MrChips
    Oct 2, 2009
    12,648
    3,459
    I'll just pop out on my bike and check it out.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    For you, a long ride.
  5. Sparky49
    Jul 16, 2011
    835
    417
    One does not simply 'bike' to maplins.:p
  6. Markd77
    Sep 7, 2009
    2,803
    594
    I was messing about with the capacitor and the little green LED last night, and just noticed it was still glowing. Turns out it's a KINGBRIGHT - L-7104VGC-Z - LED, 3MM, 9000MCD, GREEN, CLEAR. I thought that was a bit odd so did a couple of measurements. The LED forward voltage is 2.17V and the current is around 500nA (0.3mV across the 560 ohm resistor - my meter only goes down to tenths of a millivolt so that's approximate). So the LED power is around 1μW.
      File size:
      35.5 KB
      33
