I want to build an interactive christmas tree where I can precisely control which light is on or off. In order to keep the number of wires limited, I thought of a solution where each led has its own I2C enabled PIC operating in slave mode, with an additional master PIC that is programmed to tell which slave to enable or disable. A 4-wire cable would then be sufficient. Nevertheless it sounds a bit too complex...
The actual logic that I need is also a bit more simple. Instead of controlling each light individually, it would suffice to interactively increment the number of leds that are on. So first LED 1 is on, next step is 1 and 2, then 1, 2 and 3 and so on.
My knowledge of electronics is a bit limited, so I wonder if anybody over here has some illuminating ideas...
