Inter-avr Communication
Discussion in 'Embedded Systems and Microcontrollers' started by Shagas, Aug 21, 2013.
  1. Shagas
    Thread Starter Active Member
    May 13, 2013
    Hey guys :
    So i'm making a project where I need to drive about 100 Led's each with independant PWM control.
    I've made a program which allows software PWM for up to 16 Led's
    I've been thinking of using multiple AVR's to controll a larger number of leds.
    I'm going to have a master and say 6 slaves .
    The way I visualise this is that the master and all the slaves will sit on the same bus .The master will be sending out an adress packet which will adress a specific slave and then followed by a data packet which will be a 16 bit array (pwm values) in two 8 bit chunks .
    The slaves will not respond , they will just recieve data for processing .
    Which communication peripheral should I use ?
    I was thinking about using the ATTINY4313-PU but it only has
    USI and USART .
    Will it work with that?
    The master can be any avr since there is only going to be one master.
    Thanks in advance for the help
  2. Shagas
    May 13, 2013
    So after an hour of discussion on AVR-freaks i've decided to go along with using Led drivers with PWM adjustment from TI:
    I will be daisy chaining them and Will need to communicate with One master AVR.
    Which communication protocol should I use?
    I read from the datasheets that there are:
    Which is going to be the fastest/easiest to learn/use with these drivers?
