Intense assembly help within 3 days...
Discussion in 'Embedded Systems and Microcontrollers' started by sanwa, Mar 26, 2009.
  1. sanwa
    Thread Starter Active Member
    Jan 18, 2009
    36
    There is an include file for my project, which is the lcd.asm.
    From my main file, i have Print_Char:
    In the lcd.asm:
    Code ( (Unknown Language)):
    1. ;---------------------------------------------------
    2. ;         Show an ASCII Character on the LCD
    3. ;
    4. ; Input: W = character
    5. ;
    6. Print_Char:
    7.     goto    LCDdata
    8.
    1. ;------------------------------------------------------------------
    2. ;              Send Data Byte to LCD
    3. ;
    4. ; Input: W = data byte
    5. ;
    6. LCDdata:
    7.     incf    lcd_address ; update cursor position
    8.     bsf LCD_RS
    9. LCD_write:
    10.     movwf   lcd_dat
    11.     call    lcd_hi
    12.     bsf LCD_E
    13.     nop
    14.     bcf LCD_E
    15.     call    lcd_lo
    16.     bsf LCD_E
    17.     nop
    18.     bcf LCD_E
    19.     goto    wait100     ; wait 100uS
    20.
    21.
    22. ;------------------------------------------------------------------
    23.
    Is this code the one that will display the character as what we can see on the LCD? (I mean decimal). As I am planning to use this to convert my binary string to readable decimal at the hyperterminal. Thanks
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    LCD needs either 4 bit (nybble) or 8 bit (byte) input. There are serial to LCD driver ICs available, otherwise, 7 pins are needed for R/W, 6 pins for write only to LCD.
    They are also somewhat fussy about timing, especially in nybble mode.
  3. sanwa
    Jan 18, 2009
    36
    I am using 4 bits by the way. Can I know anything frm this?
